Maytag refrigerator Model LRSW24A AM81A
Condenser Fan Motor Kit
I'll be installing a Condenser Fan however there are three screws in the mounting bracket which are in a very tight area and one is on the backside of the motor and the typical Nut Driver or ratchet can't fit in the tight space.
I only have the standard tools available and I was wondering if there was a tool with a flexible shaft or a some other special tool that could allow me to bend the shaft a sharp right to access the one screw behind the mount in such a tight space.
I'm trying to install the motor to save significant amount of money so any assistance would be appreciated.
Thank you
