AppliancePartsPros.com
Appliance Repair Help
Dishwasher Repair
Bosch Dishwasher skips to "clean" even after part replacement
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I recently replaced the program module (programmed), Heat pump (circulation pump) and drain pump on my dishwasher. It has started draining and washing again but most of the time after about 5 minutes its skips all the way to clean and resets. Occasionally it will do most of the cycle then throw an E24 error. What else could need to be replaced to fix? Thanks. Model number SHP865WD5N/01
Dishwasher Repair
