Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hey I have an issue with Frigidaire water/ice dispenser model FFHS2322MSKA. It sprays water out the housing / light when trying to dispense water. It started after I changed the filter. Sounds similar to this issue I found but I couldn’t work out how to get the dispenser bezel/housing off. I unscrewed the only screw under the drip tray but nothing is budging and I’m scared of snapping the plastic if I force it. Any tips? https://www.applianceblo...-at-the-same-time.79735/
