Joined: 5/5/2023(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png)
We noticed that our GE GTW460 washer doesn't seem to spin after the Delicates cycle. We also tried Drain and Spin. The washer goes through a drain cycle but never spins.
I put the washer into diagnostic mode and put it in the spin test. The washer went through a 4 minute spin cycle. I also tried a Light cycle, and the washer went through the spin cycle at the end.
Error codes present 16, 18, and 4.
It looks like I need to check the drain, but is there anything else I should look for?
Thanks!
