Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I try to replace the GE radiant element so I follow up the instruction to remove the class top. After removing a few screws, there are 3-4 sticky screws which can not be removed. I thinks these screws may be damaged. Do you have any suggestion? thanks
