AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GE Hydrowave often doesn't finish cycle; powers on/off during fill
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
About a month ago, I started noticing frequent beeping after starting a new wash load. During the fill cycle, it's like the whole unit just powers off and back on quickly - sometimes a few times within a minute. After tearing the control panel apart, checking/reseating all connections, and doing the same with the motor and inverter assembly, it got to the point to where it wouldn't power back on at all. Not being able to find the best electrical diagrams other than some online diagnosis, I decided to just replace the motor/inverter since it was likely the culprit. After installing that, everything appeared to work fine for a few weeks. Yesterday, I noticed that it was on a constant fill and drain for a few hours. It's like the fill cycle runs and something causes the power to cycle real quick so when it starts back up, it goes through the drain routine before filling again and just in this infinite cycle. I have used an extension cord to try a completely different outlet on a different circuit, but it didn't help. The other major component that I have not replaced is the control panel/board, but since I don't think it has much brains in the operation, I didn't want to throw money at it for no reason. This is the replacement motor I purchased. WH20X10094 (AP5688892): https://www.appliancepar...h20x10094-ap5688892.htmlAny advice is appreciated, even if that is to look at purchasing a whole new unit.
Washer Repair
