My washer won't go into high spin unless there is barely no load or no load at all in the drum. Meaning if I have more than 3 sweaters, it wont go into high spin. It does spin slow. There is no standing water in the drum so the pump is working. I have to take out all the clothes, wring them out of water, then put 1/4 of them back in, then it will go into high spin. No error codes Edited by user Friday, February 24, 2023 10:28:52 AM(UTC)
| Reason: Not specified
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
well for those of you who end up looking for a resolution, the problem has been resolved. there was a sensor on the top of the drum that was faulty, I jumped the sensor and the washer went into high spin. I replaced the part and it works great now.
