Kenmore Coldspot model 106.9555611 Type: C25SSA96 the water dispenser is not dispensing any water. My model does not have a water filter so it's not that. I have replaced the Water inlet value and the ice maker has been working the whole time. When I put a glass in and press on the switch for water I can hear it running from the inlet value but nothing is coming out so I think the switch is good on the door.
Also I did an ohm test on the old inlet value and it tested out fine for resistance. With the new inlet value in there the ice maker is still working like it was with the old value.
Any help is greatly appreciated.
Phil Reynolds
Groups: Expert
Copied this from another website.Its a good place to start.
"Water Tube in Door is Frozen... To determine if the water supply tube is frozen, disconnect the tube at the bottom of the door and blow air through it. If air does not pass through, this indicates that the water supply tube is frozen. If the water supply tube is frozen, thaw it out. In addition, ensure that the freezer is kept at the proper temperature. The freezer temperature should be kept from 0-10 degrees Fahrenheit. If the freezer is too cold, the water line may freeze."
Also the water reservoir or tank in the fresh food side, might be frozen up. Its usually behind the crisper drawers. If it gets below freezing, it can freeze up.
