AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Maytag front load won't stop draining and is locked
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a 5 year old Maytag mhw3505fw and yesterday I went to start it and it would not run. It locked the door and started draining but nothing else was on the screen and I could not cancel the cycle or unlock the door. I unplugged it several times and tried to hold down the cancel and power button but nothing. It would just start draining with nothing coming out. I finally unplugged it and left it overnight. This morning it was the same thing so I did some research and found that I could press the press the temp, soil and spin buttons 3 times and then the control panel would come on. If I pushed soil twice it would stop draining and I would get a code C00 and when I pressed power it would reset everything but then start draining again. I found a video on how to manually unlock the door and unplugged it and did that and it stopped with the draining and it seemed normal again. I ran a load and it got stuck at 8 minutes remaining and kept draining. I had to hit the pause button and then restart it and it dropped to 1 minute and finished the cycle. After this I did a rinse and spin and it went just fine with no issues. It drained and unlocked when it was done. Again, I started a new load after this and it went fine but at the end it kept draining and the door locked button was flashing. I pushed the temp, soil, spin buttons 3 times and then the soil button twice and I got the C00 code and held down the start button and the door unlocked and it was fine. What is my issue? Do I just hope it does not happen again or is this a sign of a bigger issue that would be fixed by replacing something?
Any suggestions are appreciated.
Thanks,
John
Rank: Guest
Same washing machine, same problem. Did you ever get this sorted out?
Washer Repair
