AppliancePartsPros.com
Appliance Repair Help
Washer Repair
whirlpool lsc8244bq0 agitates during rince and spin cycle
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Originally Posted by: wilsonjiaho  something is exciting the transmission to run continously. is there an electrical diagram? im not sure about electrical diagram i can pull one up online if needed but nothing has been changed or replaced since we got it 10 years ago i do know that for some reason it will work perfectly fine, agitator will free spin when tub drains and spins but thats only about 1 outta 15 attempts. ive heard some people say it could be the start capacitor or something like that
Rank: Guest
Originally Posted by: wilsonjiaho  something is exciting the transmission to run continously. is there an electrical diagram? problem started as 1 in 5 washes messing up then went to 1 outta 3 then every wash in about 2 months time
Groups: Expert
What I'm trying to say is any money spent on trying to fix this machine might be better used to buy a working used washer or a new one. https://www.appliancepar...n-3360629-ap3096209.htmlThe shaft assembly is $114 and the transmission around $300. Replacing one of these parts will probably fix your machine. But all the rest of the washer is the same age. The timer or motor could go next... Something to think about. I don't get paid to do this. I don't get anything if this site sells parts. I'm just volunteering my time and what little knowledge I've picked up in the last 33 years.
Washer Repair
