Jeff
#1 Posted : Sunday, January 22, 2023 8:39:51 AM(UTC)
Guest
Rank: Guest
United States
I've got a ~4 year old GE french door fridge GFE28GMKJES - water dispenses, but no ice.
Things I've tried:
  • Water Filter
    Installed, not expired, no warnings on display
  • Defrosted the ice maker cabinet with hairdryer.
  • Test "00 37 - FF Door ice Cabinet Thermistor Test".
    Left digits=20 and slowly dropping as it recovers from defrost.
    Right digits flash 52,25,97,84,56,43,70,29,15,2,88,74, (continues).
    What are all those codes? I assume error codes, but still looking for err code descriptions.
  • Test "00 66 - FF Door Icemaker Rake Motor Test".
    Slight hum from vicinity of rake motor, but motor doesn't turn
  • Test "00 65 - FF Door Icemaker Water Valve Test"
    No sound, no water, nuthin. I wonder if it doesn't do it because its not cold enough yet?
  • Test "00 43 Cycle Duct Door" (Opens the Duct Door for 10 seconds and then closes it)
    Success
I guess I'm going to give it 24 hours to stabilize after the defrost and if still no ice I'll order the ice maker. What do you think?
Cheers,
Jeff
Edited by user Sunday, January 22, 2023 9:33:51 AM(UTC)  | Reason: add description field
jeff.gilbert
#2 Posted : Thursday, January 26, 2023 2:59:52 PM(UTC)
jeff.gilbert
United States
Welp.
I installed the new ice maker and the Rake Motor Test still doesn't do anything.
I see now that there are two tests:
0066 FF Door Icemaker Rake Motor Test
0059 FZ Door Icemaker Rake Motor Test
Tried both tests. Nothing happens.
I'll give it a day and see if I get ice, but I'm not hopeful.
Help?
