Hello, I have a new Samsung Washer top load washing machine, the one with the Glass lid and the sink. It is a two piece lid, and it is supposed to have the slow or soft close feature. It does not soft close, it slams shut. If I separate the lids from each other, they will slow close individually, but when the sink and lid are latched together it falls shut.
There has got to be a way to adjust the tension on the hinge mechanism, but I can't find anything. Do any of you know anything about this?
I would call Samsung for warranty, but to tell the truth, I'd rather fix it myself than have to mess with their "Certified Technicians" that they send in from 2 hours away. The last time they tore the washing machine apart 3 separate occasions making it worse each time. Samsung replaced the washer as a lemon... and gave me this one... one that works right.. but the lid doesn't. Is this an easy fix, or do I need to mess with them again?
Thanks for your help...
Sam
Nobody has messed with a door hinge with slow close?? Surely one of you have.. Sam
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Recommendation to replace tension rods DC61-04129A and slow release lifters.DC97-19700D
