AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Less than two year old top load Maytag Washer Lid Hinge broken
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I am having the same problem, 3 years old left hinge. You pay. Something for a washer and breaks so quickly. I hope Maytag will se they are at fault and resolve our issues
Rank: Guest
Same issues washer is not three years old Broken on left side has to pushed down to lock Over a $500 dollar fix
Rank: Guest
Same exact issue with us. Maytag washer left hinge broken and cracked. Our is 3 years old. I called Maytag today and they said they haven't heard of the issue. There should be a recall. What a disappointment!
Rank: Guest
I have replaced the lid twice because the plastic over the left hinge broke. Today the third lid broke in the same place--left hinge. This is an obvious design flaw and when i called Maytag, they would do nothing. I will never buy another Maytag!!!
Rank: Guest
Same issue here but Kenmore out of warranty and repairman said know issue but no recall.
Rank: Guest
Same issue here. Boy,would I love to join a class action on this one!
Rank: Guest
Same issue here with my MVWX655DW1. It's about 3 years old, left hinge plastic broken.
Rank: Guest
Remove back from washer and remove the spring from the lid assist.
Rank: Guest
Same issue. I bought machine because it said Maytag which I thought was a superior build. This is shocking and clearly inferior. I have to run the machine with a broken lid and get lid lock error codes when things don’t align. We need relief from this.
Rank: Guest
I’m so discouraged reading all your posts. I’m having the same issue with the left hinge on my Maytag washer lid. Now I don’t know if I want to invest the money to replace the lid since some of you have done this only for it to break again a few months later! I, like many of you, purchased a Maytag product for their reputation only to have the defect in their product that they don’t wish to acknowledge.
Washer Repair
