I replaced the evaporator fan, that's what cured the problem for me, my 20 yr old fridge has been running fine ever since :D
Originally Posted by: richappy You have a simple, mechanical cold control in this, most probably a bad/burnt wire to the evaporator motor. After it comes to desired temp. It's an 02 model .the compressor is running fine it seems can you help me??
I have an 02 Frigidaire side by side . The fan in the freezer is pulsing on /off after it reaches desired temp in freezer side an refrigerator side. What could cause this?? Do I unblug the refrigerator or let it run until I can get it checked out?
Originally Posted by: Sunshines I have an 02 Frigidaire side by side . The fan in the freezer is pulsing on /off after it reaches desired temp in freezer side an refrigerator side. What could cause this?? Do I unblug the refrigerator or let it run until I can get it checked out? Were you able to find a fix sunshines? It seems I have the same fridge one year newer with the same problem. I defrosted the evaporator coils, checked the fan it seems to be working properly but haven't put a meter on it. Any help would be great.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Why does my 2005 side-by-side refrigerator Frigidaire refrigerator the evaporator fan keeps pulsating
Rank: Guest
