Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
While replacing a clutch due to broken shaft I have been unable to remove the rootr from the ncluch shaft and therefore cannot get to the stator so can rebuild the entire assembly on the new clutch assembly.
Rank: Guest
Spin cycle leaving too much moisture
Rank: Guest
