Hello-
We have a fine Bosch range with a gas cooktop and electric oven HDI7282/U09. Over its 10 years of use, the red LED display has grown pretty dim. I suspect the problem is the electrolytic capacitors in the display module (Bosch 00653424).
I would like to try to replace the capacitors myself. Would you happen to know what value of capacitors this module takes? Is it possible to find a schematic of the module?
Many thanks!!
