My Frigidaire fef326asa oven does not shut off when it reaches the selected temp. I have had an F1 Error code appear on the display once, but not every time. The range still works okay. As far as I can tell with my analog meter, the thermostat probe reads approx 900 ohms resistance. I understand that it should be between 1090 and 1100? Would this be significant? Should I order both the Clock/Control Panel part and the Probe? Please advise.
