Amateur Repairman123
#1 Posted : Sunday, November 27, 2022 12:13:14 PM(UTC)
United States
My Kitchenaid oven was taking over 30 mins to heat to 350.
No easy access to elements so had to pull the oven from the wall
Tested the bottom element at all good 29 ohm
Checked the top elements and both were around 30 ohms so obviously not an element issue.
Removed the top cover to see the main control board covered in soot with a hole burned through by one of the large relays
Replaced the board and all is good. Reaches temp in 11 minutes
