the clock on my gas range does not keep the correct time. everything else seems to be working fine. Any ideas?
Depend on how big is the difference and how important it is for you your choice is to keep it as is or replace the clock. If you would like to replace the clock and need the correct part number then post the complete model number of the range.
the model number is 66575801001. I would like to replace the clock.
The part number for the clock is AP3180904gene.
