AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
A Maytag dryer, how to hook up a replacement motor?
Hello, Pros. In a Maytag dryer, model LDG8616AAE, # 1 the bearings in the motor died. The dead motor is Part # 6 3033580-7, Model # S58NXEET-4784, looks like # 2 # 3 A new motor was ordered, and the replacement motor is Part # W10410892, Model # S58SVEET-7126, looks like # 4 # 5 I do have the wiring schematic for the old motor, but the new motor did not come with any wiring diagram. Can anybody tell me how to hook up the new motor? Maybe... was I given the Wrong replacement motor? Thanks very much for your time. Mark531 File Attachment(s): Mark531 attached the following image(s):
Excellent! THAT was the wiring diagram that was needed. Thanks, Ohm.
Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have the same issue as Mark, trying to replace my Maytag LDE412 dryer motor but the wiring is different. Same pictures as Mark posted. Can Ohm please resent the schematic on how I'm to wire the new motor because it isn't visible anymore. Thanks!
Dryer Repair
