I have a GE Model JBS55W0K4WW. The oven has no signs of life.
I traced the problem to the control board and found two diodes on the board that are shorted (one was actually burned in half) after a lightning strike. The board and component designation are
Board: T09-2K5 8RF4B10210601 27-Sept 2005 V05
Diodes: D103 ZD102
Does anyone have a part number for the diodes? Not a GE part number, but the actual manufacturer's part number that would be on the part if it weren't too damaged. I'd rather replace those than pay for the entire board. All relays are functional as well as all other diodes, etc.
Thanks in advance, Billydanger
