tyson8000
#1 Posted : Wednesday, May 27, 2009 4:40:43 AM(UTC)
tyson8000
Hi, there is no water getting to my bottom spray arm, there is water to the top which i assume comes from the same pump? I removed the arm and checked the holes, everything clear. I started the wash cycle without the bottom arm in position and when i opened the door some way through, there was no water flow from the bottom outlet. Is there some sort of solenoid on each feed pipe, which may not be activating to allow the bottom to get water, whilst the top is still allowed to be fed? Any suggestions would be appreciated, thanks.
#2 Posted : Wednesday, May 27, 2009 5:11:01 PM(UTC)
The model number you posted does not come up. Verify and repost it please.
tyson8000
#3 Posted : Thursday, May 28, 2009 11:25:03 AM(UTC)
tyson8000
Hi, The model i have is a Kenwood KDW243A, this option was unavailable from the drop down menus. Thanks:)
#4 Posted : Thursday, May 28, 2009 7:12:28 PM(UTC)
Unfortunately we are not able to find any technical information for non American models online.
