Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
This freezer just died. Power is good and the light comes on inside. Became completely silent, no clicks no motor noise. So far I have replaced the evap fan, the defrost timer, the start relay, and the part with three pins that the relay is attached to. Still the same, dead no start. Is there some way to short some pins or provide some power to pins to force it to start if the temp control switch is bad or a thermistor? Thank you for help.
