This is a duplicate post but, I forgot I had an account here so posted under it :)
My Maytag washer is stuck in Sensing mode. It will lock the lid, then a LOUD click, spin, then stop, and repeat. After a minute or so, it will drain the tiny bit of water that went in, and says the cycle is complete.
I've tried resetting, by unplugging for one minute. Also read to turn the water off, unplug for a minute, then turn the water back on.
I cleaned that water inlet filters, and also checked that the pressure is good.
Unsure how to run diagnostics. But this washer just ran 2 or 3 loads, and then started doing this.
