jztjzt
#1 Posted : Sunday, July 24, 2022 7:04:23 PM(UTC)
jztjzt
You have been a member since:: 3/23/2019(UTC)
United States
Dishwasher has been working fine up until last night. Absolutely no power to the control panel so I can't select any wash settings or start it. Have found a possible cause is that the thermal fuse needs to be replaced. Have watched several videos on how to do it, however there is nothing on my control panel that looks remotely similar to the different types of fuses I've seen in the videos. For the KDTE304DSS0, where exactly is this fuse located at??? I've attached a picture of my control board for reference.
Thank you!
Jzt
control board
CoreyB71
#2 Posted : Saturday, August 13, 2022 4:45:34 AM(UTC)
CoreyB71
United States
I just had the same issue. I don't think it is on your motherboard. Mine was by itself, hanging in a clamp on the side where one of my motherboards were mounted. Mine had two black wires connected to it. Both should be "hot". Unless your fuse is bad, then one is hot and one is not.
