Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My maytag dishwasher started leaking several days ago. I've cleaned everything I can and removed the door panel. There was a lot of gunk at the bottom of the door(inside and out). I cleaned it all. When I run the dishwasher on "rinse only" water just pours out from the bottom of the door. I'm not sure how to figure out the problem. It doesn't appear that my model has a bottom door seal. Model MDB6769PAS4.
thanks,
Here's a video of the dishwasher leaking. Maytag Dishwasher leak Same poster as original, just registered. Any help would be appreciated.
