AppliancePartsPros.com
Appliance Repair Help
Microwave Repair
Removing and replacing inner door of Kitchenaid KBMC140Hss03
I have a broken inner microwave door. Its held in place by two pins, one on each side coming from a the door hinge inside the cabinet. How do I remove the inner door to replace it ? If I can remove the door hinges part number AP6009298, then I would be able to take the inner door out and replace with another one. This is a microwave/oven combination unit KEMC307Kss03), but only the microwave door is broken on it. The microwave by itself is not sold anymore and Kitchenaid does not have a direct replacement. I looked ta the pictures on Appliance parts Pro, but still not sure how to take out and replace the inner door. There are other broken things like outer door frame and torsion springs, but I can replace those.
Microwave Repair
