Joined: 7/6/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: SD
whirlpool commercial coin op cae2743bq0 - Lid lock will not release drain pump running for like 20 min then shuts off lid stays locked. No lights. Cannot run diagnostic. Try to start goes right to drain pump running. Is this a lid switch problem? Is the brake actuator doing same function as shift actuator? My first time to encounter a brake actuator.
