Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 1 time(s) in 1 post(s)
Hi experts! I have a KitchenAid Range KGRS807SSS00, with stove and oven in one setup, and the oven's bake burner suddenly does not ignite any more. I checked out the help article on this website for my issue (https://www.appliancepartspros.com/repair-help/kitchenaid-range-kgrs807sss00-repair/kgrs807sss00-wont-start.html), but I'd love to get a second pair of eyes on this from anyone! Thanks in advance for your help!
Issue: when I tap on the bake button, I can hear the gas coming out in the oven, the igniter then makes four attempts to light the fire, however the oven burner is not lit. The rest part of the appliance works fine, including the stove top and the upper broiler burner. Could this be a bad spark module? Is there anything else in the system that could be broken?
