AppliancePartsPros.com
Appliance Repair Help
Washer Repair
How to remove PCB Assembly - LG Top Load Washer WT7600HKA
Joined: 7/4/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Florida
I have an LG Model WT7600HKA Top Load Washer that I need to replace the PCB Board.
The instructions in the service manual for the WT7600HKA do not show exactly how to access and remove the PCB from the front panel.
They have a simple description without proper photos. This is what they say in the Service Manual:
1. Pull The front panel back. 2. Remove 1 screw on the protect cover. 3. Disassemble the protective cover. 4. Disconnect the leads from the controller. 5. Remove 7 screws on the PCB assembly. 6. Remove the PCB assembly.
Here is my problem: they do not show HOW to remove the metal cover which must be removed to access the PCB assembly. It does not appear to be simple.
I need proper photos and preferably a video for my model.
Have any of you ever worked on this model?
Can you help me with this problem?Edited by user Monday, July 4, 2022 9:13:34 AM(UTC)
| Reason: Fix syntax
Washer Repair
