I have a Samsung RF23J9011SG refrigerator with an ice maker that will not fill with water. I purchased from Appliance Parts Pros, have replaced the the 2 way water valve and the ice maker. But still not getting water to fill the ice maker tray. I do get water dispensed from the front panel so water pressure seems good. The ice maker's auger cycles when I push the reset button but I don't hear the water fill. Are there other part(s) that might need replacing to signal water is needed to fill the tray?
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
How do you reset it? Where is the button?
