Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello picked up this dryer used and not working. Figured it was the main board. Replaced and no power still. Replaced user interface board.
No inside light when door is open.
There is a very faint dim light on the display on both the old and new board
Led flashed fast on the main board when it's first plugged in then slow flashes after a minute or 2.
Rank: Guest
This is OP. Tested the thermal fuse & Door switch.
