Joined: 6/14/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: va
Washer has worked for years, gives error code OE. no kinks, washer level, removed pump an bench test an it is good. removed clothes an left about 3 gal. water an ran it on spin an it works. put load back in fill tub an it spins but no drain. hooked 110 to pump motor and it pumps tub dry. No LG repair guys less than 3 hrs. away an cust service no help. any help out there?
