Rank: Guest
Groups: Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
My Maytag bravos XL is about 6 years old ,was leaking underneath and water wasn't getting extracted completely, checked the pump ,it's good, so then when I put the pump back on I checked the valves for the hot and cold ,with the relays on top of it, the hot water slot was clogged ,and wasn't filling up with water,infact no whater was coming into the washer at all ,hot nor cold,so I replaced the inlet valve with the relays on Top ,and now it's allowing water into the washer ,hot and cold ,but now during a cycle the washer does not wash ,just senses ,fills and drains the water ,but it skips the wash cycle all together ,it does spin only when on sensing mode ,but no spin during wash mode. Any ideas what it can be?
