AppliancePartsPros.com
Appliance Repair Help
Washer Repair
GTW460 stuck in drain mode and Sensing Fill light flashing
Joined: 5/4/2022(UTC) Posts: 0 ![United States United States](/Content/images/flags/US.png) Location: Illinois
My GTW460ASJ4WW was stuck in drain mode so I tried letting in run till it stopped like advised in another forum here. The only difference is the Sensing Fill light flashing. I have also tried plugging and unplugging 5 times to reset. When I start a new load it doesn't do anything for a few minutes then goes into the drain mode again.
I also tried a new control board, did the same thing.
Washer Repair
