DaniJo9
#1 Posted : Tuesday, May 3, 2022 5:42:33 PM(UTC)
DaniJo9
United States
I noticed a drip coming from the detergent dispenser & it wasn't happening after every load, but it was enough to make clothes soggy if not removed right away. It's pretty steady when it does happen, I timed 8 drips every 10 seconds. I checked the dispenser & it wasn't dirty or clogged, I turned off both the hot & cold water supply & it eventually stopped. I turned the hot water supply back on & no dripping, within 5 seconds of turning on the cold water supply, the drip started again & much faster. Would this be an inlet problem or something else & how do I test it? I have pics but unable to attach. Thanks for any insights!
