Maytag MAV6000AWW The water pumps out. Sometimes it will start to spin, then stops. It never agitates. I installed the thrust bearing kit and a new belt. It still doesn't spin. I can see the belt turning and the pump works fine. If I turn the thrust bearing pully by hand in both directions, the tub does not rotate or agitate. What else could it be? Thanks Edited by user Saturday, April 23, 2022 8:36:11 AM(UTC)
| Reason: More info
Groups: Expert
We went for the new machine. Thanks.
