Jackof Altrade
#1 Posted : Thursday, May 28, 2009 2:42:19 PM(UTC)
Jackof Altrade
This may be a stretch due to the age of the machine, but I am hoping to find a wiring diagram for the timer for this gas dryer. When I pulled it out I noted that the tabs were labeled and that the wires were labeled as well. What I failed to note was that the power wires to the drive motor were not labeled and the wires to the buzzer were not labeled either. Now I need to determine which tabs they are connected to. Thanks in advance for your help.
sidfink43
#2 Posted : Friday, May 29, 2009 4:15:51 PM(UTC)
sidfink43
See if this site helps. Use the first six characters as your model number, as your full model number does not come up.
http://www.frigidaire.com/manuals.aspx
Good luck, and let us know if this works
Jackof Altrade
#3 Posted : Friday, May 29, 2009 7:52:47 PM(UTC)
Jackof Altrade
Yep, that's it, and in the immortal words of Elvis P. Handyman, "Thank you, thank you very much".
sidfink43
#4 Posted : Saturday, May 30, 2009 12:17:19 PM(UTC)
sidfink43
Great, glad that worked out for you!
