I have a LG wasing machine and it quit working mid cycle. It had smoke coming from the control panel and smelled like electrical wire burning inside the panel. Did LG have a problem with the panels? Would a timer do this? Any help wiound be greatly appreciated.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0 Location: 99556 Was thanked: 4 time(s) in 4 post(s)
I have a LG WT7600H*A.ABWETUS that I am trying to change the inlet valve on. I am unable to remove the control panel cover, it doesn't seem to come off following youtube instructional videos and I am leery about using too much force.
