Ge Washer GTW460ASJ8WW, tub not spinning on any setting, example I put in on normal load it says sensing, then you here a popping noise several times, tub won't spin, then after a couple of times Washer just shuts off need help?
Rank: Guest
Groups: Guests
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Drum locks up when going to spin out
Rank: Guest
Groups: Guests
Drum locks up when going to spin out LG washer model WM2301HW
