Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Hello,
I need help with connecting the existing cables inside the dryer to the board. It is the white and green/yellow cable. I do not know which goes where. Im using a 4 prong connection. The connection are installed as described by the manufacture. However i do not want to make a mistake with connecting the extra wires that are from the inside the dryer to a wrong connector.
4 prong connection green to the ground what to neutral red to red black to black
insinde Ege dryer not connected
please help thank you
