Joined: 3/24/2022(UTC) Posts: 0  Location: Pennsylvania
Hello all, hoping for some help diagnosing this issue. Freezer is ranging in temp from -4 to 13 before compressor kicks on... Frozen food (like meat) is staying frozen, but bread etc is thawing. All the while Fridge temp is ok...
When I set to lowest temp setting, freezer will now cycle between -8 and 7 degrees (I am using a wifi govee temp sensor).
So my thoughts are the thermistor in the freezer may be off and to replace that first.
Does that track and make sense?
Thanks all for your thoughts,
-Carl
