Model 796.41072310 Kenmore front load washer. Small amount of water pools under back right corner when washer is not in use. Checked exterior connections. Supply hose connections are good and intake filters and pump filter all clean. Leak is inside the cabinet somewhere, and because it's a 10 year old washer (that already needs a new boot), I thought I'd ask in case some immediately obvious answer is well known to more experienced pros. I'd like to get a sense of what I'd be looking at for repairs, before dissembling a 10 year old washer. Thanks
