Webekin
#1 Posted : Wednesday, March 16, 2022 5:42:24 PM(UTC)
Webekin
United States
Caravell 335-945 model Ice cream Display freezer, lowest setting, still well under 0 degrees
while compressor and fan run constantly. Thinking the thermostat is faulty or compressor run relay.
Your thoughts??
ThatGuy
#2 Posted : Wednesday, March 16, 2022 7:02:15 PM(UTC)
ThatGuy
Groups: Expert
United States
0 degrees Fahrenheit? Do you want it colder than 0? Its not necessary to run it that cold. If it can't get below 0 F, then it might be a little low on freon. Is the condenser coil clean and is it hot?
Webekin
#3 Posted : Friday, March 18, 2022 3:00:11 PM(UTC)
Webekin
United States
Happy with temp. in the box. Disappointed that the unit runs all the time, never shuts off.
Pulled the Temp. control/thermostat, looking for replacement, that is compatible. Thanks in advance, Dale
