Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
When I run a wash cycle it stops midway and give me the error code about not draining properly. I have to unplug it and wait a few to reset the codes. If I run a drain and spin it completes the cycle though. I’ve cleaned the drain filter and hose that comes out the back of the machine. What else could be causing this?
