I have an LG washing machine that is doing 2 weird things: 1. It's recently started to turn on by itself - not actually running a load, but just turning on the display panel and making a beeping sound. 2. At other times, I load the washer to run it, but it won't turn on - like there's no power. I unplug the cord, plug it back in, and it starts up and runs the load without any other issues.
I've heard it could be a control board issue. Any confirmation or other ideas? Thanks.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Washer will not turn off water to washer
