My freezer is working fine but the refrigerator is warm. I have cleaned the coils, fan is working and the compressor is running. Would appreciate any help. I have the repair parts list for the refrigerator.
Thank you.
Groups: Expert
Is there any frost on the back wall of the freezer? If there is frost, you have a defrost problem.
Any other ideas on how to solve this issue?
Thank you
I read where replacing the capacitor would clear the issue of a cold freezer and warm refrigerator.
Does anyone know if this is true?
Groups: Expert
Is the evaporator fan running? Is there any air flowing to the refrigerator area from the freezer coils? Your model number didn't come up right. Is it an over and under, with the freezer on top?
Sorry, where is the evaporator fan? The fan at the bottom back end of the refrigerator is working. I have not checked the fan that is located in the freezer (I assume that is the evaporator fan). I note feel any air flow to the refrigerator. I have not noticed any ice build up, but did notice that there is condensation in the refrigerator (top).
The freezer is located on top.
Thank you.
Groups: Expert
The evaporator fan is in the freezer. When the refrigerator is running, the fan should be running too. It blows the cold air from the freezer through a system of ducts to the fresh food section. No aitflow, no cooling.
