jnymdnyt
#1 Posted : Saturday, July 28, 2007 9:20:53 PM(UTC)
jnymdnyt
Aloha from Hawaii!
It looked brand new from the begining, little did we know it doesn't work. Everytime I turn the oven on either bake or broil after 1 minute a "FS" message is displayed on the control panel. The oven doesn't heat up at all. If anyone knows what this means I would highly appreciate it.
Please HELP.
Much Mahalo,
John G
Admin / APP Team
#2 Posted : Sunday, July 29, 2007 11:10:38 AM(UTC)
Admin / APP Team
Rank: Administration
Groups:
John,
Are you sure the code reads FS? Maybe F5 or F3? Please double check and let us know.
jnymdnyt
#3 Posted : Sunday, August 5, 2007 10:40:22 PM(UTC)
jnymdnyt
Yes it is F5. What does that mean? Thanks.
jnymdnyt
#4 Posted : Monday, August 6, 2007 12:41:41 AM(UTC)
jnymdnyt
Disregard last post because I saw the F5 error code already. The ERC is the problem. Wonder how hard is it to replace. Much Mahalo again.
reifnote@msn.com
#5 Posted : Monday, August 6, 2007 6:27:44 AM(UTC)
reifnote@msn.com
I am having the F 3 code flash. All I did was replace the ignitor on the broil burner. It just involved connecting the two wires. What could I have done to cause this problem?
Admin / APP Team
#6 Posted : Monday, August 6, 2007 5:36:07 PM(UTC)
Admin / APP Team
Groups:
John,
Control is number 16 on this diagram.
It's usually pretty simple to replace. The wiring might be slightly different, but the new board should come with instructions.
reifnote - post your oven model number. Codes vary depending on brand and model. F3 usually stands for a problem with the oven sensor.
