No matter what setting I put it on it goes to drain and spin But it doesn't spin. I've even done the reset and it'll go through the whole motions of the reset but then as soon as it's done it goes right back to saying 10 mins on the display and attempts to drain and there's no water in the tub. I took out the pump to see if there's any obstruction and it's clean and clear. When it starts draining starting from 10 mins once it gets to about 6 mins it'll beep then completely turn the washer off. Has anyone else experience this situation, both of my Cabrio washers are doing this and I cannot figure out why this is? I changed actuators and they're not the problem, kid switch isn't the problem either and pump works perfectly
