rick33
#1 Posted : Sunday, December 12, 2021 12:22:21 PM(UTC)
rick33
Have an old WR55X10942 which I've replaced the main board on at least 5 times over the past 12 years. The other day the water stopped dispensing again so another board needed.
Tried to use the diagnostic codes for the first time. Based on what I could find 01 put it in demo mode, 15 does a soft reset. I tried several codes and think I may have done something else to it because now it won't turn on, no compressor, no cooling - but the lights and the panel work.
code 15 sounded like it reset something inside, even tried unplugging and plugging it back in but the compressor now not running. Any ideas what else I can try?
EDIT : Well figures after posting it would decide to start up! Took it about 90 minutes but the compressor kicked on and appears to be running now. Still no water but expected will have to get another board to fix that issue.
Edited by user Sunday, December 12, 2021 12:29:08 PM(UTC)  | Reason: Not specified
